Teraz jest So lis 21, 2026 10:43 am
PostNapisane: Pt mar 28, 2014 11:34 am
Dołączył(a): Pn mar 24, 2014 11:49 pm
No cóż chciałem umieścić tą informacje w wiadomościach z świata RC ale się nie dało więc wklejam to tu jest to dość istotna informacja szczególnie jeżeli ktoś się ściga nie tylko w Polsce.
MUFFLERLIST 2014
For any enquiries please refer to: muffler.homologation@efra.ws
March 4th 2014
Enclosed the new muffler list for 2014. Because of new rules the list has been changed. Some of the older
mufflers have disappeared. From now the responsibility on the noise production is up to the driver. Using one of
the mufflers on the list does not mean that you are within the limits. The noise production depends on a
combination of motor/muffler/manifold/ins-box/gearing and body. During 2014 EFRA will start measuring noise
limits to show the drivers their noise production. From 2015 on we will slightly reduce the limits year by year,
which means that some of you will need to change their set-up, depending on what has been set as maximum.
A penalty will be given to those not respecting the noise limits. This is a different approach compared to the last
25-30 years, however this is the only solution to bring the level down. All mufflers will be valid for a period of 2
year and then a renewal by the manufacturer has to be made to EFRA again. This gives better control and the
more noisy mufflers will easily disappear in the future.
The “RED” coloured numbers are new mufflers or new INS boxes. At the end of the list you see a sample of the
EFRA9901 with a picture. We have also listed some of the measurements here, including the weight. The
weight is there to avoid the production of mufflers with thinner or different material. Thinner material normally will
produce more noise. Within the next weeks pictures from all the mufflers with their dimensions and weight will
be added to complete the list. Length and diameter are the maximum values. Some mufflers have a cosmetic
change compared to those produced some years ago, which means they are slightly different looking, however
functional measurements are still the same. See picture EFRA9901 with extra reinforcement for tailpipe.
EFRA Number 1/8th MUFFLERS for 2014 type valid till
EFRA9901 NovaRossi dec-15
EFRA2006 NovaRossi dec-15
EFRA2015 NovaRossi / R&B dec-15
EFRA2017 MAX dec-15
EFRA2021 Schepis Model , Boss, Sirio, Bliss dec-15
EFRA2031 Radiosistemi dec-15
EFRA2033 PICCO/XCEED/SONIC/VOX/REDS/LRP/BLISSRC dec-15
EFRA2034 RCE/Hipex dec-15
EFRA2041 Mielke dec-15
EFRA2042 OS Engines / AmainHobbies/ Mugen Seiki/Nemo/S-workz dec-15
EFRA2045 R&B dec-15
EFRA2048 Radiosistemi dec-15
EFRA2046 PICCO/XCEED/SONIC/VOX/REDS/LRP/BLISSRC dec-15
EFRA2052 NovaRossi dec-15
EFRA2058 Capricorn / XRD / Orion dec-15
EFRA2068 Capricorn / XRD on road dec-15
EFRA2069 RCE/Hipex/CRF dec-15
EFRA2076 LRP off road dec-15
EFRA2083 Schepis Model , Boss, Sirio, Bliss dec-15
EFRA2084 NovaRossi dec-15
EFRA2087 R&B dec-15
EFRA2089 OS Engines / AmainHobbies/Nemo/S-Workz dec-15
EFRA2090 SST/Alpha/A-plus off road dec-15
EFRA2092 R&B dec-15
EFRA2094 MAX dec-15
EFRA2095 Hipex (low noise pipe) on road dec-14
EFRA2096 NovaRossi dec-15
MUFFLERLIST 2014
EFRA2097 R&B dec-15
EFRA2098 OS Engines dec-15
EFRA2099 PICCO/XCEED/SONIC/VOX/REDS/LRP/BLISSRC dec-15
EFRA2100 Hudy/Xray/FX dec-15
EFRA2102 Schepis Model , Boss, Sirio, Bliss dec-15
EFRA2103 Arrow/Go-Engine off road dec-14
EFRA2104 REDS Racing off road dec-14
EFRA2105 Global Hobbies off road dec-14
EFRA2106 HsiChia Co. Ltd / Weiken off road dec-14
EFRA2107 SST/Alpha/A-plus off road dec-14
EFRA2108 RCE/Hipex/FX dec-14
EFRA2109 LRP off road dec-15
EFRA2110 SST/Alpha/A-plus off road dec-15
EFRA2111 Force(FC)/Conrad/Carson/J Perkins/Ofna/Sworkz off road dec-15
EFRA2112 REDS Racing off road dec-15
EFRA2113 REDS Racing on road dec-15
EFRA2114 CRF / Orion dec-15
EFRA2115 RCE/Hipex/OS Engines dec-15
EFRA2116 PICCO/XCEED/SONIC/VOX/REDS/LRP/BLISSRC dec-15
EFRA2117 Gimar / JP dec-15
EFRA2118 Capricorn / XRD dec-15
EFRA2119 Ultimate Engines off road dec-15
EFRA2120 PICCO/XCEED/SONIC/VOX/REDS/LRP/BLISSRC dec-15
EFRA Number 1/10th MUFFLERS for 2014 type valid till
EFRA2624 Mielke on road dec-15
EFRA2630 NovaRossi on road dec-15
EFRA2652 NovaRossi / R&B on road dec-15
EFRA2654 RCE/Hipex/Orcan on road dec-15
EFRA2660 NovaRossi / R&B on road dec-15
EFRA2661 OS Engines on road dec-15
EFRA2662 Capricorn / XRD on road dec-15
EFRA2663 Mielke on road dec-15
EFRA2668 R&B on road dec-15
EFRA2669 RCE/Hipex/CRF on road dec-15
EFRA2670 MAX on road dec-15
EFRA2671 Schepis Model , Boss, Sirio, Bliss on road dec-15
EFRA2672 OS Engines on road dec-15
EFRA2673 Hipex / RCE (low noise) on road dec-14
EFRA2674 REDS Racing on road dec-15
EFRA2675 RCE/Hipex on road dec-15
EFRA2676 Capricorn / XRD on road dec-15
EFRA2677 Gimar / JP on road dec-15
EFRA2678 PICCO/XCEED/SONIC/VOX/REDS/LRP/BLISSRC on road dec-15
EFRA2679 PICCO/XCEED/SONIC/VOX/REDS/LRP/BLISSRC on road dec-15
MUFFLERLIST 2014
INS Boxes for 2014
EFRA-INS200101 Serpent 1/8th 1/10th
EFRA-INS200201 Picco box, also sold by R&B 1/8th 1/10th
EFRA-INS200401 Mielke / Mugen Seiki 1/8th 1/10th
EFRA-INS200701 NovaRossi 1/8th 1/10th
EFRA-INS200702 Mielke modified / Mugen Seiki 1/8th 1/10th
EFRA-INS200901 NovaRossi / R&B 1/8th 1/10th
EFRA-INS200902 Serpent / Xceed / Max / OS Speed /R&B 1/8th 1/10th
EFRA-INS200903 modified NR (lower 200901) 1/8th 1/10th
EFRA-INS201001 Hobby Pro / Team C 1/8th 1/10th
EFRA-INS201101 Mielke 1/8th 1/10th
EFRA-INS201401 NovaRossi 1/8th 1/10th
EFRA
number
Manufacturer OEM brands Picture Specs date/mm/gr
Valid till 31-12-2015
EFRA9901 NovaRossi Weight 68.5
Diameter 38
Lenght 156
Tailpipe 26
cron
