Teraz jest N wrz 06, 2026 1:44 pm
Utwórz nowy wątek Odpowiedz w wątku  [ Posty: 371 ]  Przejdź na stronę Poprzednia strona  1 ... 4, 5, 6, 7, 8, 9, 10 ... 25  Następna strona
PostNapisane: Pn maja 19, 2008 8:25 pm
Chyba nie bardzo, 5A BEC nie wytopiłby kabli zasilających, miałem podobnie w HV Novaka i wszystko zaczeło się od mosfetów z wstecznego a tu ciekawostka:
"The load from the motor determines how much current is drawn from the batteries. Batteries don’t push current, hence you cannot have too large or too high a discharge battery. The ESC, between the motor and the batteries has two jobs. First, it run the motor by analyzing the motors back EMF then sending commutation pulses to the motor based on its analysis of the motor. This involves much more than knowing the position of the rotor, there are several complex algorithms that, by analyzing the back EMF, set the computation pulse advance to get the most power and efficiency of out any motor is it running.
Its second task is to control the speed of the motor to the users command. It does this with Pulse Width Modulation or PWM. PWM works by turning full throttle current on and off very fast. The portion of the pulse that is 'on' in relation to the part that is 'off' determines how much power the motor sees. I.E 50% on, 50% off the motor sees 50% power. The PWM switching rate is 13,000 times per second (13 khz). DC power sources, in this case batteries, do not like high current being switched on and off, they want to put out steady current. The ESC wants to see square waves, instant full on, instant full off. However, the battery takes time to go to full on and won't switch off immediately. This creates a sloped instead of a square wave. The caps on the ESC are there to get the PWM pulse back closer to a square wave. The reluctance of a battery to put out pulsed current also creates a side affect called 'ripple current.' The caps also control ripple current. The less capable a battery is of keeping up with the current demands of the motor the higher the ripple current. If the capacitor overheats or get completely drained from inadequate batteries the caps will burn or blow up and the ripple current cascades thought the power board burning up the ESC. The other primary cause of ripple current is resistance on the battery side of the circuit. A plug with too much resistance, long or too small battery wires, bad connections etc. will increase ripple current, possibly to catastrophic levels. I cannot prove it but my guess is that more of our ESCS are burned up from inadequate batteries than over current.
The minimum discharge rating for cells used with a Monster Max is 75 amps continuous, burst to 150 amps. This is a minimum to keep ripple current low enough to make sure the batteries don’t damage the ESC, more is better. Also, the more capable the batteries the more torque the motor will produce.
To answer the question of why don’t NiMh batteries damage the ESC is the fact that these cells voltage drop quickly under load then climb back. The drop in voltage protects the system from the motor pulling too much amperage and creating too much ripple current.
With high power electrical systems, the battery is the most important part of the system. Saving money on batteries not only gives lower performance, it puts the ESC at risk. Choose your batteries wisely.
Bernie Wolfard
Supervisor, Product Support
Castle Creations
235 S Kansas Ave.
Olathe, KS 66061"
czyli jeżeli dobrze zrozumiałem to MMM wymaga 75A :evil: ciągłego prądu od zasilania bo inaczej się popsuje :D, NiMH i mniejsze LiPo żegnajcie tylko LiPoFe zostają ??????
 Zobacz profil
PostNapisane: Pn maja 19, 2008 8:47 pm
Tak, przeczytalem tylko poczatek posta :oops:
Gdzies tez przeczytalem o spalonym reglu i trafionych lipolach z powodu zwarcia w silniku Feigao :(
Maciej Stąpór
1:8 - HB e-LSP, HB e-L2PE
PostNapisane: So maja 31, 2008 7:16 pm
Duza czesc awarii powodowal podobno wiatraczek :/
Upgradeowana wersja bedzie dostepna od polowy czerwca.
Maciej Stąpór
PostNapisane: Wt lip 15, 2008 4:13 pm
a tu koledzy twierdza, ze te regle nie maja zadnych problemow i z nimi wspolpracuja:
http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... TQ:DE:1123
ciekawe, twierdzą że to wersja softu 1.17, produkcja z polowy maja, wolna od wad,ma zamiast gniazd kable wlutowane. Wg nich pierwsze wersje mialy problemy we współpracy z nadajnikami PPM a nie z BEC, używają i sprzedają je bez problemu podobno.
PostNapisane: Wt lip 15, 2008 7:28 pm
Tylko co kilka dni "przypadkiem" na forach sa opisywane kolejne zejscia regli :/
Wersja firmware nie ma zadnego znaczenia.
MMM mialy byc z goldami na plycie fet'ow, ale z powodow "technologicznych" wlutowywali jednak kabel.
Sprzedawca musi sie jakos pozbyc towaru :/
Szczerze mowiac bardziej przekonuje mnie wlasciciel i glowny inzynier CC.
Wczoraj po ostrych beta testach ruszyla produkcja MMM ver. 2. Pierwsze sztuki wpadna w lapki osob, ktore zawiodla MMM ver. 1. Kolejne do nowych nabywcow i posiadaczy dzialajacych ver. 1,a chcacych wymiany.
Patrick zapowiedzial "kilka zmian" w porownaniu z pierwowzorem.
P.S. Mam nadzieje, ze TH dostanie duuuuuuuuuuzo MMM. Zalegam gdzies na liscie oczekujacych :(
Maciej Stąpór
PostNapisane: Wt lip 15, 2008 8:42 pm
No cóż, teoria o psuciu się regulatorów poprzez pakiety o zbyt małej wydajności prądowej należy włożyć miedzy bajki. Chyba że spadki napięć są tak wielkie, że zakłócają pracę stabilizatora zasilającego procesor. Ale to świadczyłoby o braku lub nieprawidłowej obsłudze tzw. brown-out w procesorze. Same wahania napięcia na zasilaniu nie przeszkadzają w pracy ani procesora, ani tranzystorów kluczujących. W odróżnieniu od pradu (nawet impulsowego), który płynie przez tranzystory.
Na czym to opieram? Raz na własnych doświadczeniach ze spalonymi regulatorami po zastosowaniu wydajniejszego pakietu (nigdy na odwrót), dwa - ze zdrowego rozsądku i fizyki. Im "twardszy" pakiet tym prąd (stały i impulsowy podczas kluczowania PWM) pobrany przez silnik może być ( i jest) większy - a to zagraża tranzystorom. Swego czasu popularne regulatory TowerPro miały ciekawą przypadłość: po podłączeniu wydajnego pakietu robiły beeeep po uzbrojeniu i... kończyły żywot. Miałem taki, więc podłączyłem go pod "twardy" pakiet, a na boczniku dałem oscyloskop. obciązyłem go silnikiem o małej indukcyjności (wysokobrotowym) i impulsy pradu podczas wydawania dzwięku osiągnęły 100A w szczycie, przy prądzie regulatora 30A i max prądzie silnika pod obciążeniem 20A max.
Przy kluczowaniu PWM sytuacja jest podobna - prąd średni jest mały, ale szczytowy może być bardzo duży, po prostu w impulsach o małym wypełnieniu. Spalenie wcale nie musi koniecznie być przy maksymalnej prędości, równie dobrze przy ruszaniu, lub gwałtownym wzroście obciążenia silnika.
Pozrawiam,
Zbigniew Bigaj
PostNapisane: Wt lip 15, 2008 9:06 pm
Rozumiem przez to ze najlepiej dobierac silnik i regiel pod wydolnosc pakietu zeby w przypadku braku mozliwosci nalozenia limotow pradu nie stracic regulatora ??
Sorry za OT
PostNapisane: Wt lip 15, 2008 11:21 pm
zbig a widziałeś kto to napisal:
Bernie Wolfard
Castle Creations
235 S Kansas Ave.
Olathe, KS 66061"
chyba tępaki w Castle nie pracują.
 Zobacz profil
PostNapisane: Śr lip 16, 2008 5:33 am
Bede testowal ta teze z 6S1P A123 w buggy :)
Maciej Stąpór
PostNapisane: Śr lip 16, 2008 6:52 am
A czym sterujesz, jaki esc?
PostNapisane: Śr lip 16, 2008 6:58 am
Po temacie topicu mozna sie domyslic rodzaju ESC ;)
Autko - HB Lightning 2 Pro Evo
Silnik - Medusa Afterburner II 36-60mm 1600kv
Konserwatywne przelozenie pod kontrola EagleTree
Maciej Stąpór
PostNapisane: Śr lip 16, 2008 7:01 am
aaaa, zle zrozumiałem, myślałem że dziś :) No ja na MMM czekam tylko ze względu na 6s i obsługę wielopolowych silników. Choć po zabawach na stole (i podłodze jak się wyrwał z ręki) martwi mnie w nich ich wysoki start, tzn wysokie obroty po starcie :( A medusa ile ma biegunów?
PostNapisane: Śr lip 16, 2008 7:26 am
Bernie Wolfard
Castle Creations
Kiedyś tez tak myślałem :wink:
Ale wysłuchałem w swoim życiu tylu "fachowców" z największych korporacji (sam w takiej pracuję) gadających bzdury, że nabrałem dystansu do tzw. "autorytetów".
W cytowanej treści są zwyczajne nieprawdy, dziwne teorie czy
złączone fakty nie mające związku. Btw. To nie jest inżynier z produkcji, tylko support.
Pozrawiam,
Zbigniew Bigaj
PostNapisane: Śr lip 16, 2008 8:54 pm
Kajman - Medusa jest czteropolowa, wyreguluj sobie krzywa gazu.
Maciej Stąpór
PostNapisane: Śr lip 16, 2008 8:57 pm
Staram sie unikn ąć expo, align jest 6 polowy, zobaczymy, w weekend montaż, dzis przyszła płyta do maxxa na jeden silnik BL :)
