Teraz jest Wt sie 18, 2026 10:45 am
PostNapisane: Wt sty 08, 2008 4:07 pm
Dołączył(a): Pn kwi 18, 2005 2:09 pm
Witam.
Czy ktoś wie kto i gdzie produkuje takie regulatory oprócz MGM ??
Jeśli ktoś ma namiary na sklep to juz wogóle bede hepi
TC4/Novak SS5800
HB Lightning GTX2/MM+7XL
Losi XXX-T ESC4s + ???
Losi Micro Desert/Xcelorin 10250KV
Lama V3 :)
PostNapisane: Cz sty 10, 2008 11:31 pm
Jeżeli do bezszczotki to np ten http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLBY5&P=7
 Zobacz profil
PostNapisane: Pt sty 11, 2008 7:18 am
Ale Phoenix jest lotniczy!!
PostNapisane: Pt sty 11, 2008 7:51 am
Faktycznie to kolejny przykład jak trzeba dokładnie czytać, oto opis:
This is the Castle Creations Phoenix HV-110
High Voltage, Brushless, Sensorless Electronic Speed Control.
FEATURES: Handles up to 36 NiMH/NiCd, cells or 12S LiPo (50V) maximum, 16 cells
NiMH/NiCd or 3S LiPo minimum
Up to 110A continuous current
to doczytałem Forward and reverse
Auto Shut Down when signal is lost or radio interference occurs
Smooth reverse exponential throttle
Audible Arming Signal
Self-calibrating endpoints: maximizes usable stick travel
Over temp motor cut-off with reset
User programmable options include:
Low-voltage cutoff with Auto-LiPo detect as default
Over-Current Protection
Brake Type
Throttle Range
Timing Advance
Cutoff Type
Soft Start ramp up prevents damage to gearboxes
Switching Frequency
INCLUDES: One Phoenix HV-110 Electronic Speed Control with 10AWG motor and
battery leads, Universal receiver connector and set up manual
REQUIRES: Receiver battery pack, Dual Opto-Coupled (no BEC)
Motor and battery connectors of modeler's choice
SPECS: BEC: None (dual opto-coupled)
Maximum Cells: 36 NiMH/NiCd, or 12S LiPo (50V)
Continuous Current: 110A
Minimum Cells: 12 NiMH/NiCd, or 4S LiPo
Switching Rate Programmable: 13, 26, or 52kHz
Resistance: .001 Ohm
Brake: Programmable
tego nie doczytałem Reversible: Yes, change any two wires
Low Voltage Cut-Off: Programmable
Size: 1.55" x 2.8" x 1.25" (39mm x 71mm x 32mm)
Weight (with wires): 5.3oz (150g)
Receiver Connector: Universal
 Zobacz profil
PostNapisane: Pt sty 11, 2008 8:11 am
lotniczy ale na nim biją rekordy prędkości w rccar
PostNapisane: Pt sty 11, 2008 11:12 am
Wsadzasz go razem z mechanicznym hamulcem do autka. Zakladasz dobry wiatrak, wylaczasz hamulec w reglu i smigasz na 8S.
Maciej Stąpór
1:8 - HB e-LSP, HB e-L2PE
PostNapisane: So sty 12, 2008 7:58 am
czyli on ma wsteczny przez zamiane kabelków ??
TC4/Novak SS5800
Lama V3 :)
PostNapisane: So sty 12, 2008 8:36 am
W bezsensorowych bezszczotkach zeby zmienic kierunek obrotow wystarczy zamienic kolejnosc dwoch dowolnych kabelkow biegnacych pomiedzy reglem a silnikiem.
Maciej Stąpór
PostNapisane: So sty 12, 2008 9:57 am
a własnie a jak kwestia współpracy tego regla z aparaturą pistoletową ?? wydaje mi sie że bedzie problem bo neutralną pozycje cyngla regiel odczyta jako połowa gazu ( chyba )
TC4/Novak SS5800
Lama V3 :)
PostNapisane: So sty 12, 2008 10:01 am
Dlaczego? Samolociarze uzywaja tez hamulca.
Maciej Stąpór
PostNapisane: So sty 12, 2008 11:06 am
hmm.... doświadczenia w modelarstwie lotniczym nie mam ale na podstawie mojego helikoptera drązek gazu idzie od dołu nie od środka. Na zagranicznych forach odnosnie adaptowania regli lotniczych do autek pojawiają sie rózne wypowiedzi.
TC4/Novak SS5800
Lama V3 :)
PostNapisane: So sty 12, 2008 11:41 am
W tych regulatorach hamulec działa po przesunięciu drążka do pozycji neutralnej co oznacza w aparaturach lotniczych położenie w dolnej skrajnej pozycji i od razu działa z maksymalną siłą.
PostNapisane: So sty 12, 2008 12:14 pm
Gdzies znalazlem, ze jest "pistol grip compatible". Gdzie idziej, ze wspolpracuje z "JR XS3 but not with my Nomadio Sensor".
W teorii wylaczasz w ESC hamulec. W aparaturze esc i serwo hamulca podpinasz do jednego kanalu przez Y harness lub jesli masz taka mozliwosc miksujesz trzeci kanal na hamulec.
Oczywiscie zapominasz o wstecznym.
Jesli mam byc szczery, to jesli nie podoba Ci sie Twoj aktualny setup czekalbym na MMM i poprosil kogos doswiadczonego o przelutowanie Twoich lipoli do 6S.
Maciej Stąpór
PostNapisane: So sty 12, 2008 2:27 pm
Wszystko się programuje w tym regulatorze. Tylko USB link trzeba kupić o ile dobrze pamiętam...
PostNapisane: So maja 03, 2008 7:40 pm
Kontynuujac topic. Natknalem sie na wynalazek zwany pistix.
http://www.offshoreelectrics.com/prodde ... rch-pistix
Powinien zadowolic wszystkich samochodziarzy pragnacych smigac na lotniczych reglach.
Tylko po co, MMM juz tuz tuz ;)
Maciej Stąpór
