Teraz jest Pn paź 05, 2026 3:22 am
Utwórz nowy wątek Odpowiedz w wątku  [ Posty: 65 ]  Przejdź na stronę Poprzednia strona  1, 2, 3, 4, 5  Następna strona
PostNapisane: Śr lis 25, 2009 7:34 am
Poza tym niektórzy podają co mogą znieść FET chwilowo, co ma się nijak do całego regla. Przy okazji się MMP kupi i pobawi.
PostNapisane: Śr lis 25, 2009 10:40 am
Właśnie dlatego CC nie podaje bo nie chcą jak twierdzą stanąć przed wyborem
- albo wypisujemy jak inni bzdury;
- albo piszemy prawdę i nasze regle będą miały gorszą specyfikację od konkurencji;
At Castle, we don't rate our controllers based on a battery size and lifetime. Rather, we rate our controllers based on temperature rise and stabilization. So if you look at something like, say, the Phoenix-ICE-100 (rated at 100A continuous) it can handle 100A for as long as you want to put 100A through it, and will temperature stabilize at about 80C (176F) with a 5mph airflow over the controller.
We decided not to put a current rating on our RC car controllers because we didn't agree with the way the industry rated controllers. There are controllers on the market that are rated at amperage levels that would actually MELT 12ga copper wire. (which is a ridiculous claim... most brushed controllers on the market that claim hundreds of amps of capability can actually only handle about 30-40A by Castle's rating method)
And so we decided not to get into an amperage "arms race" with companies that deliberately mislead the public.
Patrick del Castillo
President, Principle Engineer
Castle Creations
generalnie wesoły wątek:
http://www.rc-monster.com/forum/showthr ... 93&page=22
PostNapisane: Pt gru 04, 2009 6:01 am
I pojawia sie oczekiwana przez niektorych MMP 1S (bez BEC)
Cytat z RC-Monster:
Here you go gents, I present to you the Mamba Max Pro 1s Special Edition speed control. Right now they are not available, we are only taking preorders at this time. The release date is set for the first week of January. Because this is a test run to see if we want to keep this as a normal product, it has not been released to distribution yet. If they catch on as we hope, they will become a permanent product. You can find the details on our website, the price is set at $149.99 which is the full retail.
Please remember that is is the 1s version, so it will not have an onboard BEC. Also this controller will have solder posts instead of wires and will not have a fan or a switch.
Those of you that do not need a 1s version, it is recommend to purchase the normal Mamba Max Pro through the normal distribution channels (IE Mike); it will be cheaper because of retail and MAP pricing and we would rather see you purchase it through a reseller.
Let us know if you have any questions fellas!
Thomas Porfert
Castle Tech Support
Maciej Stąpór
1:8 - HB e-LSP, HB e-L2PE
PostNapisane: Pt gru 04, 2009 7:47 am
Wiem że do znudzenia, ale pochwalę GM w tym miejscu ;) Każdy, nawet stary model regla zawodniczego działa do 1s, BEC ma, ale trzeba podać nawet z malutkiego LiPolka np. 300mAh 2s napięcie na odbiornik do zasilania procesora regla pod koniec biegu. Ale BEC działa :)
PostNapisane: Pt gru 11, 2009 6:35 am
MMP 1S: http://www.castlecreations.com/products ... ecell.html
W koncu pojawil sie przenosny programator + castle link w jednym
http://radiocontrolzone.com/showthread.php?t=257926
Przypomne jeszcze, ze z nowym firmware MM mozna programowac rowniez przez castle link
Maciej Stąpór
PostNapisane: Cz gru 17, 2009 7:19 am
Kilak slow jeszcze o funkcji CHEAT
We are also producing a lot more power -- for example, a 21.5 turn motor with fixed timing produces about 108 watts at the 50% efficiency point (I know- - the design of the motor is TERRIBLE!) We are getting about 190 watts output from the same motor at the 50% efficiency point, by changing the timing and commutation method.
Maciej Stąpór
PostNapisane: Cz gru 17, 2009 9:08 am
No no VT fajna sprawa trzebaby jeszcze to porownac z VT innych producentow i jak znosi to silnik.
PostNapisane: Cz gru 17, 2009 9:46 am
silnik to zawsze znosi źle :) MM5700 jeździ u mnie trzeci rok magnes jak nowy. SP 9.5T jeździ jeden sezon i to nie dla tego, że jest złą konstrukcją
wyczyn zawsze kreuje dewastację
PostNapisane: Cz gru 17, 2009 1:13 pm
No tak, wyczyn...
Moja poczciwa MM 4600 ma 500W (test na ET), motorki sensorowe 100, 200, 300W. Ktory ma wiec zla konstrukcje?
Maciej Stąpór
PostNapisane: Cz gru 17, 2009 1:56 pm
Maciolus mysle ze odpowiedni sensorowy motorek i MM wogole niema podejscia ;) 200-300W to maja silniki 3500-3800kV ;)
PostNapisane: Cz gru 17, 2009 2:10 pm
Maciolus napisał(a):
No tak, wyczyn...
Co ty mówisz, sensorowe po 600-800W mają, to czy mają sensory nic nie robi.
PostNapisane: Cz gru 17, 2009 2:24 pm
właśnie czytałem specyfikację Nosrama to porównywalne BL z Kv w okolicy4600 mają 200-400W
GM Evo jakieś 50W więcej
w zależności od ceny. Nie wiem co tam Maciek zmierzył (mówię o tych 500W) więc nie mam pojęcia jak to ma się jedno do drugiego...
PostNapisane: Cz gru 17, 2009 7:28 pm
Wziął szczytowy prąd zapewne :)
PostNapisane: So gru 19, 2009 2:32 pm
Oczywiscie, ze pisze o maksymalnej mocy. Jaka inna porownywac jezeli wykres napiec i pradow wyglada jak pila namalowana przez psychopate z zaburzeniami postrzegania czasu? IMHO to nie jest lotnictwo zeby bawic sie mocami ciaglymi czy chwilowymi.
Przy okazji to 300W mocy sredniej wyciaga moj bagus osemka, a 400W truggy, a nie mutacja dwupolowego Novaka z puszka S...
Swoja droga chetnie zrobilbym test sensorowego motorka z MM Pro:
1. zapis w trybie bezsensorowym
2. zapis w trybie sensorowym bez funkcji CHEAT
3. zapis w trybie sensorowym z funkcja CHEAT
Maciej Stąpór
PostNapisane: N gru 20, 2009 12:35 pm
Może kiedyś w końcu zanabędę ET i pomierze to i owo...
