Teraz jest N paź 04, 2026 8:39 pm
PostNapisane: Pn sty 11, 2016 10:40 pm
Dołączył(a): Cz lut 19, 2009 12:00 am
Sprzedam duży serwis do Team Durango - 60 nowych, zapakowanych części, których wartość katalogowa oscyluje między 320 a 350 usd.
Oddam całość jako komplet, bez możliwości kupienia pojedynczych części za cenę 400 zł (do małej negocjacji).
LP nazwa części / numer
1 Rear Bulkhead set TD330009
2 Front Bulkhead set TD330003
3 Cover Set (front diff, mid drive cover) TD310038
4 Suspension Arm Rear TD330005
5 Suspension Arm Rear TD330005
6 Suspension Arm Rear TD230036
7 Suspension Arm Front TD230037
8 Suspension Arm Front TD230037
9 Suspension Holder aluminium FF TD330004
10 Differenctial Case TD310021
11 RR Suspension hanger insert TD330309
12 Geared Diff Outdrive TD310030
13 Diff Gear 9T TD310003
14 Diff Gear 14T TD310001
15 Djoint driveshaft set TD310153
16 Mid driveshaft 68mm longlife steel rear TD310229
17 Driveshaft front TD310114
18 Big bore shock preload nuts aluminium TD330554
19 Big bore shock preload nuts aluminium TD330554
20 TiNitride Rear shock shaft TD330332
21 TiNitride Front shock shaft TD330331
22 Hinge Pin: Front susp outer 27mm TD330039
23 Hinge Pin: Rear susp outer 30mm TD330041
24 Hinge Pin: Front susp outer 27mm TD330039
25 Hinge Pin: Front susp outer 27mm TD330039
26 Hinge Pin: Front susp inner 45mm TD330038
27 Hinge Pin: Front susp inner 45mm TD330038
28 Hinge Pin: Rear susp inner 52mm TD330040
29 Hinge Pin: Rear susp inner 52mm TD330040
30 Hinge Pin: Rear susp outer 30mm TD330041
31 Hinge Pin: Front susp outer 27mm TD330039
32 Hinge Pin: Rear susp outer 30mm TD330041
33 Rear Hubs: 1 pair / 1 degree Toe-in TD330007
34 Big bore shock cap TD330181
35 Spur Gear 87T 48DP TD310020
36 Spur Gear 87T 48DP TD310020
37 Moulded Cross shaft and gear set TD310290
38 Mid drive Clamp TD310018
39 Driveshaft bushing 2,0mm TD310113
40 2mm hex ball m3x7mm TD330602
41 Body snap pin 10 pc TD390003
42 Driveshaft pin B-type TD310120
43 Steering knuckle bushing TD340004
44 Two way sliper fixings TD210037
45 lock nut m3 low profile TD715001
46 Pivot ball B-type TD330034
47 Driveshaft Boot wheel Axle TD310023
48 Driveshaft Boot wheel Axle TD310023
49 Anti roll bar front 2,0mm TD330051
50 Anti roll bar front 1,7mm TD330390
51 Anti roll bar rear 2,0mm TD330052
52 Anti roll bar rear 1,7mm TD330392
53 Thurnbuckle (Steel) TD330129
54 Silicone O-ring P3 3x2mm 8pc TD330609
55 ARRMA Slipper Pad AR310018
56 ARRMA Spur Gear 87T 48DP AR310019
57 ARRMA Pinion Gear 22T 48 DP AR310062
58 Robinson Racing pinion 19T 48P hardened 1419
59 Robinson Racing pinion 22T 48P hardened 1422
60 Crunch Spacer Front Axle TD310032
| TL XXX-S G+ | TraxxIce Rally | Dex410V3 |
Użytkownicy przeglądający ten dział: Brak zidentyfikowanych użytkowników i 16 gości
