Teraz jest N wrz 06, 2026 10:40 pm
PostNapisane: Pn mar 04, 2013 12:14 pm
Dołączył(a): Cz gru 03, 2009 6:06 pm
Na sprzedaż idą:
1. Regulator GM Genius z fabrycznym softem Ref. N°. 7165. Sprawny w 100% nigdy nie zawiódł. Pudełko i papiery w komplecie. Fotki dla zainteresowanych.
Dobra cena 250zł + przesyłka ok. 10zł Pocztą Polską
Product information
- New software specially designed for model cars and boats, but also suitable for model aircraft.
- GM-Genius 85 and GM-Genius 100: splashproof case (sensorless operation only)
- New special brake software provides several different braking characteristics
- Automatic detection of brushed + brushless motors
- Automatic detection of motors with Hall sensors
- Unprecedented standard of control and start-up characteristics with sensorless brushless motors
- Ideal for competition use >= 5 min.
- Optimised heat-sink for improved cooling (supplementary water-cooling possible with GM-GENIUS 50, 85, 90)
- Four drive programs, simple to set:
Modes 1 - 3 with forward / neutral / brake mode for competition use
Mode 1: for normal track conditions, with standard NiMH low-voltage power-down and active special brake software
Mode 2: for high-grip track conditions, for maximum acceleration and braking, with lower NiMH low-voltage power-down.
Mode 3: for slippery track conditions, with LiPo low-voltage power-down (optimised for four cells)
Mode 4: forward / neutral / brake / reverse, with standard NiMH low-voltage power-down
- All supplementary functions can also easily be programmed individually using the IDA programming system with Programmer, GMVIS-Commander(V2005) or PC (Windows 2000 or XP)
- Programmable supplementary functions such as automatic brake, maximum brake, maximum reverse speed, ABS, speed limiting, soft-start, minimum brake, full brake, automatic throttle, power curve, motor timing, current limiting, start-up current limiting, turbo and different braking characteristics.
Specification
Operating voltage range: 4.8 ... 12 V
Number of cells, NiCd, NiMH: 4 - 10
Number of cells, LiPo, LiIo: 2 - 3 (Mode 3)
Continuous current (brushless motors): 50 A
Max. motor current (10 s.): 80 A
Temperature cut-off: approx. 120° C
EMF brake: programmable
Reverse: programmable
Soft-start: programmable
Low-voltage power-down: yes
Power-on pulse suppression: yes
Pulse frequency: 8 kHz
BEC receiver power supply approx. 5.5 V / 4 A peak
Max. BEC dissipated power at 20° C: 2.5 W
OPTO: optional
Dimensions excl. capacitors approx. 48 x 40 x 20 mm
Dimensions incl. capacitors approx. 65 x 40 x 20 mm
Weight excl. cables approx. 70 g
Weight incl. cables approx. 100 g
Connector: JST/G2 (Tamiya)
4. Pakiet LiFE Graupner Nanophosphate 4600mAh 6,6V nr katalogowy 7682.2S2P . Pakiet po około 30 ładowaniach – pożyje jeszcze bardzo długo. Wchodzi spokojnie 100% pojemności. Pakiet ma przedłużone o parę centymetrów kabelki do zasilania zakończone goldami 4mm.
Cena 100zł z przesyłką
Product information
Performance: Continuous discharge current 30C, and 60C peak possible.
Discharge to 2 V per cell is possible.
Durability: The metal casing protects the cells. The nanotechnology allows up to 1000 cycles. (NiMH 50 - 300 cycles, LiPo 50 - 150 cycles, with comparable discharge current)
Fast charge up to 100% possible within 15 min. (only with Ultramat 16, Ultramat 17 and Ultra Duo Plus 50.
Specification
Cell count /voltage 2x2 / 6,6 V
Capacity 4600 mAh
Max. discharge current 135A (peak 10 s 135A
Weight approx. 332 g
Dimensions approx. 139 x 55 x 30 mm
5. Pakiet LiFe Graupner Hardcase 3400mAh 6.6V nr katalogowy 98972. Pakiet ma za sobą jakieś 50 ładowań, czyli jeszcze sporo posłuży.
Cena 90 zł z przesyłką
LiFe-Akkus mit Schutzgehäuse
Entladung: 20-35C Dauerstrom
Entladung bis 2 V/Zelle möglich
Die LiFe-Technologie ermöglicht bis zu 1000 Zyklen. (NiMH 50 - 300 Zyklen, LiPo 50 - 150 Zyklen, bei vergleichbarer Belastung)
Schnellladung im LiFe-Lademodus
Ladeverfahren Konstantstrom/Konstantspannung (CC/CV) Max. Ladespannung 3,6 V/Zelle
Die spezielle LiFe Technologie ist überladungssicher bis 4,2 V und verhindert das bei LiPo so gefährliche thermische Weglaufen
Alle Akkupacks mit Graupner-Balancerstecker
Technische Daten
Abmessungen ca. 137,5 x 46,5 x 23,5 (25) mm
Geeignete Regler GM-GENIUS 90
Gewicht ca. 280 g
Kapazität 3400 mAh
Max. Entladestrom 100 A
Stecker G4
Zellenzahl/Spannung 2/6,6 V
Zdjęcia i dodatkowe informacje dla zainteresowanych na e-mail.
list@suchacz.com.pl
tel. 791888275
2x TC4, 2x TB02, TB EVO 5
