Teraz jest Pt paź 09, 2026 8:39 am
PostNapisane: Cz cze 03, 2010 8:54 pm
Dołączył(a): Pn cze 26, 2006 9:48 pm
Części zamienne i tuningowe Nanda NRX 18 Wyprzedaż.
Posiadam prawie wszystkie części serwisowe i tuningowe do modelu Nanda NRX 18.
Części zamienne
NUMER NAZWA CENA
NA2001 Chassis 10
NA2002 Upper Deck 10
NA2003 Antenna Set 10
NA2004 Front Bumper Set 10
NA2005 Pro 180 Motor 15
NA2006 Battery Holder Set 10
NA2007 Damper Spacer 10
NA2008 Gear Differential 15
NA2009 Upper Arm Set (Rear) 10
NA2010 Upper Arm Set (Front 6°) 10
NA2011 Lower Arm Set 10
NA2012 Shock Tower 5
NA2013 Damper Ball Stud 10
NA2014 Steering Ball Stud 10
NA2015 Damper 10
NA2016 Rear Knuckle 10
NA2017 Front Knuckle 10
NA2018 Universal Set 10
NA2019 Ball Cup and Connector 10
NA2020 Steering Linkage Bottom 10
NA2021 Steering Linkage Top 10
NA2022 Rear Toe linkage 10
NA2023 Disk Break Set 10
NA2024 Standard tire and Wheel Set 15
NA2025 Servo Saver Set 10
NA2026 Drive Shaft 10
NA2027 Spur Gear(36T) 10
NA2028 Plastic Motor Mount 10
NA2029 Pinion Gear(21T) 10
NA2030 Shaft Bevel Gear Set 10
NA2031 Body Mount 10
NA2033 2mm Spacers 10
NA2034 1mm Spacers 10
NA2035 Bulkhead 10
NA3001 Upper Arm Set (Front 3°) 10
NA3004 Wheel Connector 10
NA3005 Dish Wheel W/Tire and inset 15
Części tuningowe
NUMER NAZWA CENA
NA3010 ball differential 35
NA3011 front one way 40
NA3012 aluminum universal set(2pcs) 15
NA3013 aluminum motor mount 30
NA3014 aluminum washer(1mm,2mm) 15
NA3015 aluminum body mount 15
NA3016 carbon battery holder set 20
NA3018 spur gear 40t 10
NA3020 carbon shock tower 10
NA3021 aluminum 4.5 suspention ball 10
NA3022 carbon main chassis 35
NA3023 carbor upper deck 20
NA3024 m type body 25
NA3025 f type body 25
NA3026 one way cup joint 10
NA3027 ball differential bevel gear 36t 10
NA3028 one way bevel gear 36t 10
NA3029 pinion gear 16t 10
NA3030 pinion gear 18t 10
NA3031 pinion gear 20t 10
NA3032 pinion gear 21t 10
NA3033 pinion gear 22t 10
NA3034 diff ring 10
NA3035 diff ball 10
NA3037 Metal Universal set 20
Ilości są spore !!!
Pytania prosze kierowac telefonicznie lub na maila
Tel. 791 339 669
mail. biuro@modelrc.pl
Marcin Sroka
Marcin Sroka
Klub Sportowy RC-JELCZ
www.modelrc.pl
tel 791 339 669
PostNapisane: Pn cze 14, 2010 12:52 pm
Nadal aktualne
Części zamienne
NUMER NAZWA CENA
NA2001 Chassis 10
NA2015 Damper 10
NA2035 Bulkhead 10
Części tuningowe
NUMER NAZWA CENA
NA3034 diff ring 10
NA3035 diff ball 10
Ilości są spore !!!
Tel. 791 339 669
Marcin Sroka
Marcin Sroka
www.modelrc.pl
tel 791 339 669
