Teraz jest Pt lip 24, 2026 3:55 pm
PostNapisane: Wt gru 25, 2007 2:25 pm
Sprzedam jak w temacie, jeden z najlepszych na świecie regulatorów zawodniczych, niesamowita moc, 4 krotny mistrz niemiec, 1x wicemistrzostwo świata,
W kpl oryginalny interface i oprogramowanie do podłączenia do komputera PC (watrtość 200zł).
cena takiego zestawu w sklepie to ponad 1000zł
Opis po angielsku:
The iCUBE is another milestone in the development of electronic speed controllers. Unbelievable performance and many new features make it an outstanding product, for competition use and demanding drivers alike.
Features
• New generation of PowerFETs with lower on resistance
• 5 optimized Power Programs developed by top world drivers (Full Power, Power Save, Team, PC and Li-Po for 2 Cells)
• Adjustable current limiter
• Adjustable brake frequency
• Auto Brake and Auto Roll adjustable
• Switch off with transmitter
• External setup button with data link
• External soldering tabs for receiver- and silicone flex wire
• Intelligent Fet Control Protection (IFC)
• Optimized current flow for lower heat
• PC-Interface for Setup and Software Update with Data recorder (Throttle position, Current, Voltage, Lap times)
• available in 3 Heatsink colors
• Input power: 4-7 (4,8-8,4 V)
• Motorlimit: 5 Turn
• Frequency: 0,5-8kHz
• B.E.C. Output Voltage: 6.0V
• B.E.C. max. Current: 3.0A
• Weight without wires: 21g
• Case size: 27x25x13,5mm
PC-Interface for iCUBE
With the PC-Interface you can easily read the data from your iCUBE. The data recorder shows you all the important data to find the last tenths of a second on the track. The graphic data view and the displayed round times help you to optimize your driving style and the settings of your iCUBE. The software can be used on all Windows platforms.
Requirements
CPU: Pentium 300 or higher
Memory: min. 128MB RAM
Harddrive: min. 10MB free space
Resolution: 1024x768 or higher
Peripherals: CD-ROM drive, USB port
OS: Windows 98SE, Windows 2000/X
Successful Racing of the Robitronic Team
Placing in the A-main at the World Championship 2004 in 1/12 and 4x winners of the German touring car championship 1/10 show the outstanding performance of the new iCUBE speedo.
Ostatnio edytowano Cz sty 17, 2008 5:45 pm przez Adrian Lutyński, łącznie edytowano 1 raz
PostNapisane: Cz sty 17, 2008 5:42 pm
up
PostNapisane: Cz sty 17, 2008 5:44 pm
bład skryptu, 2x się to samo wysłało.
Użytkownicy przeglądający ten dział: Bing [Bot] i 6 gości
