Teraz jest Cz lip 30, 2026 6:38 am
 Tytuł: Mala wyprzedaz
PostNapisane: Pn lip 03, 2006 6:58 pm
Raflee
Znowu znalazlo mi sie kilka rzeczy, ktore mam do sprzedania... :)
Spektrum Telemetry - fabrycznie nowe, nie uzywane, tylko otworzone opakowanie - 400zl
Opis producenta:
It’s a tool that no serious racer will want to do without – a tool that gives you the kind of information that helps you tweak your car for maximum performance. And it's all packaged in one convenient box. If you’re a serious racer, you’re probably way ahead of us in figuring out Spektrum Telemetry’s benefits. But we’ll list them nonetheless. There are benefits like engine-saving feedback to help maximize performance while preventing costly failures and rebuilds. And the elimination of dumped rx packs means no more crashes or DNF’s due to battery failure in nitro-powered vehicles. Besides that, Spektrum Telemetry’s lap timing helps you analyze the effectiveness of tire and gear selections, suspension tweaks, etc. Plus it backs up race organizers’ lap counting systems. Add its RPM sensing to give you a handle on your car’s actual speed, plus the Quality of Signal feature to monitor RF link strength, and you’ve got the whole package.
Ever wonder what you should do with that empty antenna hole on your radio once you upgrade to a Spektrum Module System? You can now mount the Spektrum Hand Held Data Recorder to your radio with the included peg that will fit every radio that Spektrum currently manufacturers a module for.
Ever wonder if your car is turning slower or faster lap times during practice? Now you can know thanks to the Spektrum Lap Counting System. Simply install the infra-red eye in your car with the included Lexan mount so that it can "see" out of your body and you're ready to go. You can now get real-time temperature information for either your motor or battery pack. Simply mount the temperature sensor to your motor, heatsink, or battery, and the temperature sensor will transmit the information to your hand held data recorder
Jest to wersja do modeli splinowych... po zmianie czujnikow mozna go uzywac w elektryku...
Tak z grubsza to chodzi o to ze dzieki temu mozmey w czasie jazdy wiedziec obroty silnika, predkosc, temp silnika (wazne w spalinkach np. w finale), napiecie akumulatora... fotke wrzoce pozneij :)
Kyosho Inferno MP-6 Intyernational - cena 450zl, daje z nim wydech, filtr powietrza, nadwozie, 6 kol (2 w dobrym stanie i 2 w bdb... jedna to slicki ;) ) Do jazdy potrzeba elektroniki + silnik. Model jest w bdb stanie technicznym... posiada 3 dyfry - przedni, tylni i srodkowy - oczywiscie mozna w nich wymieniac oleje itp... model przygotowany do zawodow - ustawiony i po zalozeniu silnika mozna jechac :))
Dorzucam sprzeglo, klosz, srobki itp... Jest to najwyzsza wersja tego modelu. Jedynie lozyska nadaja sie do wymiany... trzebaby jeszcze kupic to co podtrzymuje sprezyne i lebek z kulka ktory jest na koncu drazka amortyzatora. Sadze ze cena jest atrakcyjna ;)
Wieczorem uzupelnie liste o jakies fotki i reszte mniejszych rzeczy.
Dlatego kochamy off-road :D
Użytkownicy przeglądający ten dział: Brak zidentyfikowanych użytkowników i 12 gości
